Imprecise flattenning / machining marks
(Soam V) #1
Hi all, I’m completely new with the Nomad (and with CNC in general), so I want to ask if this is a problem with my machine or just something normal that I should expect:
This was produced by a simple “flattening” operation – carving a pocket that’s about 1mm over the entire surface of the piece using carbide3d’s 0.25" bit. I saw this effect on another piece with the smaller 0.125" bit as well.
I was expecting a surface that would not have these pronounced machining marks; for this piece it is very easy to sand them off, but for finer details / pockets it will be trickier and more time consuming. Again, I don’t know if this is a problem with the machine or something I should just expect to deal with with the Nomad.
I figure this happens because the bit is not perfectly perpendicular to the xy plane…so I’m also wondering if there is some sort of “fine adjustment” available I can adjust somewhere in the spindle holding assembly to improve this?
Thoughts?
(William Adams) #2
Please increase your stepover.
Also, leave a roughing clearance, and take only a chipload’s thickness off as a finishing pass.
(mikep) #3
Will meant to -decrease- stepover. This is pretty common in wood, the fibres lift up like that. If you decrease the stepover (to about 3/4 of the end mill width) it’ll overlap the passes and you won’t see that.
(Soam V) #4
I’ll try out these suggestions, thanks!
(system) closed #5
