Bronce - Brass
Tool: 1/8" flat endmill
Feed rate: 7.874 in/min (200 mm/min)
Plunge rate: 0.656 in/min (16.66 mm/min)
Spindle speed: 12,000 RPM
Max pass depth: 0.003" (0.07 mm)
Tool: 1/16" flat endmill
Tool: 1/32" flat endmill
Tool: 1/64" flat endmill
Feed rate: 1.575 in/min (40 mm/min)
Plunge rate: 0.157 in/min (4 mm/min)
Max pass depth: 0.001" (0.02 mm)
Tool: 1/100" flat endmill
Tool: Engraving bit
Max pass depth: 0.003" (0.07 mm) Keep in mind the engraving tool has a variable width, depending on your “engraving cut depth.” The deeper the cut, the wider the tool. The shallower the cut, the narrower the tool. If you’re using an engraving tool and the generated path isn’t cutting part of your .svg file, try reducing the engraving cut depth.
Advanced Feeds and Speeds for Brass
Warning: These settings are for advanced users. Before using any of the information provided here, you must read the section above on fixturing your material, and you must have a way of precisely measuring your material thickness (we recommend digital calipers). The feeds and speeds specified here are more aggressive (and thus faster), and improperly fixtured material can be knocked loose and damage itself and your machine. Additionally, the material surface needs to be completely flat, or else 1/32", 1/64", and 1/100" end mills will break when they encounter part of the material that is sticking up.
Lastly, if you’re using tools smaller than 1/16", you must make sure that the tool is removing the correct amount of material on the first pass, or else your tool may cut too deep and break. All subsequent passes will be correct, but the first pass can be affected by anomalies like tape thickness, burrs on the material edges, and material warping, all of which can increase the height of the material surface, causing the tool to cut too deep.
Feed rate: 59 in/min (1500 mm/min)
Plunge rate: 5 in/min (127 mm/min)
Spindle speed: 16,400 RPM
Max pass depth: 0.002" (0.05 mm)
Feed rate: 30 in/min (381 mm/min)
Plunge rate: 1 in/min (25 mm/min)
Feed rate: 5 in/min (127 mm/min)
Plunge rate: 0.5 in/min (12.5 mm/min)
ABS
Feed rate: 23.622 in/min (600 mm/min)
Plunge rate: 1.575 in/min (40 mm/min)
Max pass depth: 0.009" (0.228 mm)
Tool: Engraving bit
Feed rate: 40 in/min (1000 mm/min)
Max Pass Depth: 0.006" (0.15 mm) Keep in mind the engraving tool has a variable width, depending on your “engraving cut depth.” The deeper the cut, the wider the tool. The shallower the cut, the narrower the tool. If you’re using an engraving tool and the generated path isn’t cutting part of your .svg file, try reducing the engraving cut depth.
Warning: These settings are for advanced users. Before using any of the information provided here, you must read the section above on fixturing your material. The feeds and speeds specified here are more aggressive (and thus faster and more fun), and improperly fixtured material can be knocked loose and damage itself as well as your machine.
Max pass depth: 0.05" (1.27 mm)
Feed rate: 50 in/min (1270 mm/min)
Feed rate: 40in/min (1000 mm/min)
Max pass depth: 0.02" (0.508 mm)
Feed rate: 30 in/min (762 mm/min)
Plunge rate:1.575 in/min (40 mm/min)
Max pass depth: 0.01" (0.254 mm)
Tool: Engraving bit
Acrilico -Acrylic
Tool: 1/64" flat end mill
Feed rate: 23.62 in/min (600 mm/min)
Max pass depth: 0.010" (0.25 mm)
Note: A 1/64" end mill should only be used for cutouts on very thin pieces of material.
Tool: 1/32" flat end mill
Plunge rate: 1.575 in/min (12 mm/min)
Note: As with the 1/64" end mill, cutouts should only be done on thinner material with a 1/32" end mill.
Tool: 1/16" flat end mill
Feed rate: 43.3 in/min (1100 mm/min) or faster
Plunge rate: 1.81 in/min (46 mm/min)
Max pass depth: 0.003" (0.08 mm)
Note: This tool should be run at at least 16,400 RPM or the material will melt to the tool.
Tool: 1/8" flat end mill
Max pass depth: 0.005" (0.13 mm)
Note: This tool should be set to at least 16,400 RPM or the material will melt to the tool.
Plunge rate: 15 in/min (381 mm/min)
Feed rate: 59 in/min (1500mm/min)
Feed rate: 51.2 in/min (1300 mm/min) maximum
Aluminio - Aluminun
Feed rate: 7.087 in/min (180 mm/min)
Plunge rate: 0.591 (15 mm/min)
Feed rate: 1.417 in/min (36 mm/min)
Tool: 1/100" flat end mill
Feed rate: 15 in/min (381 mm/min)
Plunge rate: 1 in/min (25.4 mm/min)
Derlin
Max pass depth: 0.008" (0.21 mm)
Max pass depth: 0.020" (0.5 mm)
Tool: Engraving bit
Max Pass Depth: 0.003"–0.020" (0.08 mm–0.5 mm) Keep in mind the engraving tool is V-shaped and thus has a variable width, depending on your “engraving cut depth.” The deeper the cut, the wider the tool. The shallower the cut, the narrower the tool. If you’re using an engraving tool and the generated path isn’t cutting part of your .svg file, try reducing the engraving cut depth.
Warning: These settings are for advanced users. Before using any of the information provided here, you must read the section above on fixturing your material. The feeds and speeds specified here are more aggressive (and thus faster and more fun), and improperly fixtured material can be knocked loose and damage itself and your machine.
Max pass depth: 0.02" (0.5 mm)
Max pass depth: 0.01" (0.25 mm)
Tool: Engraving bit
Max Pass Depth: 0.003"-0.020" (0.08 mm–0.5 mm) Keep in mind that the engraving tool is V-shaped and thus has a variable width, depending on your “engraving cut depth.” The deeper the cut, the wider the tool. The shallower the cut, the narrower the tool. If you’re using an engraving tool and the generated path isn’t cutting part of your .svg file, try reducing the engraving cut depth.
Ceras - Wax
Feed rate: 37.402 in/min (950 mm/min)
Max pass depth: 0.013” (0.32 mm)
Tool: 1/16” flat end mill
Max pass depth: 0.014” (0.36 mm)
Tool: 1/32” flat end mill
Max pass depth: 0.016” (0.40 mm)
Tool: 1/64” flat end mill
Max pass depth: 0.005” (0.13 mm)
Tool: Engraving bit
Feed rate: 39.370 in/min (1000 mm/min)
Max Pass Depth: 0.003" (0.08 mm)
Note: Keep in mind that the engraving tool has a variable width, depending on your “engraving cut depth” parameter. The deeper the cut, the wider the tool. The shallower the cut, the narrower the tool. If you’re using an engraving tool and the generated path isn’t cutting part of your .svg file, try reducing the engraving cut depth.
Plunge rate: 20 in/min (500 mm/min)
Max pass depth: 0.118” (3 mm)
Max pass depth: 0.059” (1.5 mm)
Max pass depth: 0.031” (0.79 mm)
Tool: Engraving bit
Policarbonato
Feed rate: 14.173 in/min (360 mm/min)
Tool: Engraving bit
Feed Rate: 39.37 in/min (1000 mm/min)
Plunge Rate: 1.575 in/min (40 mm/min)
Spindle speed: 12000RPM
Note: Keep in mind that the engraving tool has a variable width, depending on your engraving cut depth setting. The deeper the cut, the wider the tool. The shallower the cut, the narrower the tool. If you’re using an engraving tool and the generated path isn’t cutting part of your SVG, try reducing the engraving cut depth setting.
Warning: These settings are for advanced users familiar with feeds, speeds, and fixturing. The feeds and speeds specified here are more aggressive (and thus faster and more fun). Improperly fixtured material can be knocked loose and damage itself and your machine.
Spindle speed: 14,000 RPM
Max pass depth: 0.008" (0.20 mm)
Tool: Engraving bit
Feed Rate: 59 in/min (1500 mm/min)
Plunge Rate: 15 in/min (381 mm/min)
Spindle speed: 16,400RPM
HDPE
Max pass depth: 0.009" (0.23 mm)
Tool: Engraving bit
Max Pass Depth: 0.003" – 0.020" (0.08 mm - 0.5 mm). Keep in mind the engraving tool has a variable width, depending on your “engraving cut depth.” The deeper the cut, the wider the tool. The shallower the cut, the narrower the tool. If you’re using an engraving tool and the generated path isn’t cutting part of your .svg file, try reducing the engraving cut depth.
Plunge rate: 19.6 in/min (500 mm/min)
Plunge rate: 19.5 in/min (500 mm/min)
Tool: Engraving bit
Max Pass Depth: 0.003" - 0.020" (0.08 mm - 0.5 mm). Keep in mind the engraving tool has a variable width, depending on your “engraving cut depth.” The deeper the cut, the wider the tool. The shallower the cut, the narrower the tool. If you’re using an engraving tool and the generated path isn’t cutting part of your .svg file, try reducing the engraving cut depth.
Madera - Wood
Max pass depth: 0.050" (1.27 mm)
Max pass depth: 0.020" (0.50 mm)
Feed rate: 20 in/min (508 mm/min)
Feed rate: 10 in/min (254 mm/min)
Max pass depth: 0.006" (0.15 mm)
Tool: Engraving bit
Spindle speed: 10,000 RPM
Mahogany
Spindle speed: 15,000 RPM
Tool: Engraving bit
