I’m trying to create a pocket and inlay with CC. The pocket is perfect but the inlay needs some adjusting. However, I’m finding it impossible to adjust the size due to CC changing it on me. Any help with this CC issue or with sizing an inlay properly will be greatly appreciated.
It should be a matter of assigning the inverse of the path for the inlay, so if you’ve cut a pocket, then you’ll want to use an Outside / Right contour.
If things are slightly off size-wise you may be able to use the path offset feature to adjust things slightly.
I’ve viewed and read all I can find on the toolpath offset but still have a question. Are the offsets cumulative? Meaning if I try a .004 offset then want to increase it by .001 will the end result be an offset of .005?
Well I thought I had this figured out. I’m trying to use the tool path offset to make the pocket a little larger. I selected 0.020 “outside” and reran the toolpath. However, it didn’t seem to expand the pocket at all. Any help will be greatly appreciated.
Just thought of something. When I set an offset do I have to define a toolpath for that offset as well? If so, how do I do that? Can I just select them as a group and set a tool path for them?
