Any chance someone with Vcarve Pro can try to see if this STL works? It shows up at first and then disappears after importing. I’m demoing version 9 but if it’s bugged then it wont be a go for me
ash_2_10cm.stl (109.0 KB)
AH… My stock is set to inch while imported model is mm. Even though the imported stl in mm is <= defined stock size in inches it does not work. Set stock units to match import units and it’s good now
