I recently purchased a Triquetra 3-axis touch probe for use with my Shapeoko 3 XL. I’ve seen other on the forum that are using the same product successfully with their Shapeoko. However, I am having problems getting it to work.
The Triquetra documentation indicates to use the Carbide 3D touch plate wiring guide as the instructions for wiring the Triquetra (wires map as follows: red to red, black to white, and green is unused). I have the 2.4e control board that has the “reserved” header for the Carbide 3D probe. Based on the Carbide 3D guide pin 1 on the header is “green”, pin 2 is “red”, and pin 3 is “white”. So, I wired the Triquetra to pin2 and pin3 on this “reserved” header.
I am using CNC.js to send the g-code to the Shapeoko. I start a z-probe to test the touch plate. The router moves as expected but does not stop then the endmill touches the plate (i.e. it doesn’t detect the plate). Here is the g-code that is being sent:
G92 Z0
G20
G38.2 Z-1 F3
G91 G0 Z0.05
G38.2 Z-0.2 F1
G92 Z21.3000
G91 G0 Z0.125
G91 G0 X1 F10
G91 G0 Y1 F10
I have tried a number of things to troubleshoot:
- Touched the two cable ends directly together as opposed to going through the plate - still no detection
- Tried a different cable and touched the exposed ends together in an attempt to get detection - no go
- Wired the cable using the older board layout as described in the Carbide 3D guide (i.e. red wire goes to a 5v pin and the white/black wire goes to the first pin the double pin header labeled “probe” on the board) - this also did not work
- Wired the red and black cable to the double pin header labeled “probe” as opposed to using the “reserved” header - again not working
What am I missing? Is there something else I should try. Do I need to enable something? How are others getting theirs to work? Any help would be greatly appreciated.
