I’m having an issue and I can’t work out why. On my X/Y axis I’m getting loads of jerky movements when running a program. I am not getting them when jogging.
I have checked V wheels, belts are all tight - I even loosened them.
I’m wondering if it’s my post processor, but not sure how to confirm.
Any chance anyone can check the attached file on their machine? I have ran it in the air and get the same issue.
I downloaded the stroom one, but it opens as open builds? I was already using this one…
I’m running Fusion 360 as the design, the open builds post pros and UGCS as the control.
I’m 99% sure it’s not a hardware issue but a software one - I just don’t know why…
Griff
(Well crap, my hypometric precursor device is blown…)
5
Luke, Adam Z posted a couple of pp’s last year, you might try one of those. Also, since CM 412 became available I’ve switched back and forth to the post that comes with F360, no issues. Inches or mm. I like CM cause I’m a simple kind of guy and it just works.
Was this by chance a SVG imported into fusion? I’ve had some really strange results from doing that - CAM decides that part of a closed shape is “outside” and another parts of the same is “inside” and lots and lots of crashes. I haven’t seen it generate weird toolpaths, but that might be because I don’t get that far before it blows up.
Nope I used the fusion text tool. I designed the text, extruded and just did an outer tool path. Ive only ever done text once before. The preview of the gcode looks OK, but I can’t see it down to the mm
In fusion you can change the arc tolerance, now this project doesn’t need any real precision so I started to lower precision. Some really useful info on tolerances below pulled from F360
I dropped or increased the arc tolerance from 0.01mm to 1 and the whole opp is allot smoother, I also added smoothing tolerance of 1mm
