I installed light burn and a j tech laser. The laser runs fine and want to switch back to cutting with the CNC. All the settings are messed up and now getting error homing and jog. How do I restore back to the standard settings for Shapeoko XXL? Really need the cutter back up to original.
For CM4 see: https://docs.carbide3d.com/support/carbideupdater/#carbide-motion-v4 to restore settings.
is that something you have to do every time you use the laser?
