Had some material left over and am working on ideas to use it up. Used VCarve and Fusion 360. 1/4" ballnose. Sanded to 320 got it wet to raise the grain and sanded 320 lightly. Soaked in mineral oil for about 4 hours.
Nice! Love the grain.
Do you mind sharing the file? I’d like to make one
Thanks a ton man. I have been wanting to try this
Is this a two side machining job?
Yes. I have put in some curves and radii to reduce sanding.
How did you get perfect alignment?
I didn’t take a picture but there are locating pins on the side face down that are milled on the first side and milled into the sacrificial board.
