Make monogram letter with circle arund it
S with circle around it.c2d (90.7 KB)
I am trying to tie this S and the circle can some one help me?
Unfortunately, Carbide Create doesn’t allow for composite objects when doing a Boolean union, so a selection of everything results in:
The workaround is to do this in two passes. First select the letter and some additional bit of non-interfering geometry and do a Boolean operation to convert it into a path:
then select the S and duplicate it
Then select one copy of the S and the outer circle and do Boolean Union:
resulting in:
Then select the inner circle and control click on the remaining letter:
(the letter needs to be the key object as indicated by a dashed selection)
and do Boolean Subtraction:
which is what I believe you want. If not, let us know and we’ll try to help puzzle it out.
