Making saddle washers - aluminium milling and holding advice
I assume they are referring to replacement brain for a motorcycle, very popular in restoring vintage bikes.
More specific is it’s a replacement for the control system to use low power kit such as low voltage switches, however they are also silly expensive, and require multiple add ons to work. I went against this and made my own…
I think I have that brand LED turn signals, little bitty things that were $45 a pop! Man they look cool though :wink:
Dan
Sounds about right, £59 here and apparently made in germany… the Chinese have done a good job of knocking them off mind. I have a set of replica bar end LED’s that are almost spot on other than the ‘moto gadet’ branding…
I am in the process of making this kind of housing. Would you share the victors for that housing. I am using Aspire CNC Software. Yours looks a lot cleaner. What did you use to make the 7/8 (or 1") round so that it seats flush on the handlebar?
I designed it in fusion, happy to send the files.
I believe I used a ball end
That would be great. What type and size of the bit?
here you go:
http://a360.co/2D136QH
I believe it was a 1/4 ball
