Manual Jogging - Faster than Fast?
(Nathan Penrod) #1
Is there a way to make the ‘Fast’ setting while manually jogging go even faster? Yes, I use the rapid position feature but I still want to jog faster.
I wanna go fast. If you’re not first, you’re last. Shake and Bake!
-Ricky Bobby
(Josh) #2
I think you could change jogging to be faster. There are default values on the controller listed here:
You could maybe modify those values, thought I’m not sure that’s supported behavior.
(mikep) #3
Yes, you can go faster, you want to set the axis maximums higher.
(John Champlain) #4
With stepper motors you do risk losing steps (position) if you try to move them too fast. Test carefully.
(Nathan Penrod) #5
It would be nice if the fast jog moves as fast as the rapid position. Do you think that would be appropriate or too fast? Thanks!
(mikep) #6
Sort of. You can lose steps accelerating too quickly (a different setting). If you reach too high a speed for your setup, the steppers will suddenly run very slowly, or slam to a stop. It’s hugely obvious when you have gone too far. To find the speed to can sustain, crank it up 1000mm/min at a time, and when you get to a point where you’ve achieved failure, take 20% off and use that.
(Tex Lawrence) #7
:smile: That sounds like a sales meeting I once went to! :smile:
