So i machined a metal plate out of aluminum, I now need to go back and put a hole in that plate. I notice in meshcam that when i create toolpaths it just creates toolpaths for the entire object, what if i JUST wanted to ream a hole through the plate? Is there a way to do this in meshcam?
You can draw in inclusion / exclusion regions (or import a DXF to indicate this).
Menu entry is CAM | Set Machine Region if memory serves.
