Hello! Not sure if introductions here are a thing, but figure it would be a good way to break the ice for me.
I haven’t been a long time owner of my Shapeoko (April '18) nor have any professional workshop or machining background. I just love learning tech and making things, be it on the computer (I am a software developer), 3D printer or recently with the Shapeoko. I mostly have designed and made parts for the machines I have, the growing hobbies (RC, Photography) that burn holes in my pocket or my motorcycle down for the winter.
I eventually want to adventure into aluminum, to fabricate parts for my motorcycle (particularly working on a dash for the additional accessories installed) but at the moment been prototyping in HDPE. I used this as an excuse in getting @Luke’s famed HDZ, along with some other Black Friday upgrades (I could easily be diagnosed as what someone in the photography world would call “GAS” - Gear Acquisition Syndrome).
In the process, while testing pins on the Carbide Motion Controller board (was working on installing new home switches and [additional] spindle control) I believe I sent 24v into a pin that couldn’t take it (POP!). So, yet again used it as an excuse to do one more upgrade, with quite the steep learning curve I have found! I decided on replacing the board, that is Mach compatible and ended up on something different than most (i.e. SmoothStepper or UCxxx), a PoKeys57CNC. I just finished getting Mach4 and the PoKeys controller working smoothly, and still need to dial in steps/unit. Also, still need to design a controller box and interface, along with rearranging wires
I think ppl share photos of their machines as if it was their kid, so…
With no experience with the other contenders, I am pretty impressed with the functionality.
I think the troubles I did have was just inexperience with Mach and some unit conversions.
To get off the ground, I just decided to go with their lower tier stepper drivers (PoStep25-32), it has the amperage rating to cover the Shapeoko’s stepper motors (and less hit to my budget). They have a more advanced stepper with wider amperage range (PoStep60-256) also with software-based configuration (+1), of course you can bring your own too; just wanted something plug 'n play for the time being. With the PoStep25, @2amp and mixed decay, it has introduced more stepper noise (particularly when holding) but might get better with more adjustments.
My first stumble was trying to convert Shapeoko’s default units/step, velocity and acceleration values for Mach4 to use (https://docs.carbide3d.com/software-faq/shapeoko-3-default-grbl-settings/). I gave up and just switched to metric on Mach4 for the time being. As I type this, I think I realized what I was doing wrong… While steps/mm needs to be multiplied by 25.4 for steps/inches, I was doing the same for velocity and acceleration! Those, I should have been dividing by 25.4.
Second stumble was the spindle control/enable for the SuperPID. This was a combination of inexperience with Mach, and PoKeys documentation wasn’t 100% clear for me. By default it has a 0-10v pin for spindle control, but SuperPID only has 0-5v or PWM input, you can get away with a couple resistors to get the 0-10v down to 0-5v but I had already had the SuperPID wired for PWM from when I was using it on Carbide’s Motion Controller. You can enable PWM for the spindle control with PoKeys, supposedly overriding the 0-10v pin (#17) but I couldn’t trust it as my voltmeter readings were telling me otherwise. So I decided on pin #20, however I still wasn’t getting good test readings, which came down to I hadn’t fully setup the spindle Min/Max RPM in Mach4. After that I was able to get the PWM spindle pin working with SuperPID, an additional pin for Spindle Enabled, and also as an added bonus, Tach out from the SuperPID to a PoKeys’ super-fast encoder (index mode). So, Mach4 can read out the spindle’s RPM too
