Need help "grbl error: unsuported or invalid g code command found in block
(Jason) #1
Hi i updated to grbl 1.1 and cm 4.0.412 and this alarm keeps popping up even when just jogging the machine has any one ever seen this thanks in advanced
(William Adams) #2
Did you use the Carbideupdater?
Please check your settings and make sure that you actually got updated to Grbl 1.1
(system) #3
