HI,
Just finished this upgrade on a XL (that was converted from a standard S3).
Fit and finish was perfect, no physical anomalies at all.
However, I do have a travel issue I am hoping someone can advise me on. The Z axis moves up and down easily and cleanly but Only 4" in total. It does not matter what I set $132= to, any number from 5 to 800 has No effect on the total travel I get when jogging. (machine is usable with this much travel, I would just like to set my router higher in the clamp)
Ive read as many posts as I can find, but cant seem to figure this out. For example, I turn on cnc, start up carbide motion, home, open the send panel and type exactly $132=199
When I send, then open log and use $$ to list, I see that $132 does indeed equal 199.
However the total distance I can jog the Z azis remains the same, if I use 199 or 5, it still travels 4" down from the home limit positon.
GRBL on the carbide board is.9g and below is my latest list - any suggestions/advice much appreciatedā¦
Thank You,
Peter
Test Waitingā¦
<Idle,MPos:-4.550,-18.500,-45.500,WPos:-4.550,-18.500,-45.500,Buf:0,RX:0,Ln:0,F:0.>
gc_not_motion
___________$$ ___________
$0=10 (step pulse, usec)
$1=255 (step idle delay, msec)
$2=0 (step port invert mask:00000000)
$3=2 (dir port invert mask:00000010)
$4=0 (step enable invert, bool)
$5=0 (limit pins invert, bool)
$6=0 (probe pin invert, bool)
$10=255 (status report mask:11111111)
$11=0.020 (junction deviation, mm)
$12=0.010 (arc tolerance, mm)
$13=0 (report inches, bool)
$14=1 (auto start, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=1 (homing cycle, bool)
$23=0 (homing dir invert mask:00000000)
$24=100.000 (homing feed, mm/min)
$25=1000.000 (homing seek, mm/min)
$26=25 (homing debounce, msec)
$27=5.000 (homing pull-off, mm)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=200.000 (z, step/mm)
$110=5000.000 (x max rate, mm/min)
$111=5000.000 (y max rate, mm/min)
$112=5000.000 (z max rate, mm/min)
$120=400.000 (x accel, mm/sec^2)
$121=400.000 (y accel, mm/sec^2)
$122=400.000 (z accel, mm/sec^2)
$130=425.000 (x max travel, mm)
$131=465.000 (y max travel, mm)
$132=199.000 (z max travel, mm)
ok
gc_dwell
___________N0 G4P0.05 ___________
gc_get_offsets
___________$# ___________
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
gc_parser_state
___________$G ___________
[G1 G54 G17 G21 G90 G94 M0 M5 M9 T0 F100. S0.]
ok
