I have received my shapeoko 3 xxl and assembled it. It did notice a rather significant bur on the end of and extrusion (looked like it had been dropped but I didn’t drop it. The packaging was not damaged): AFTER I pushed on the right Y carrier whereupon I also noticed 2 nicks in 2 wheels that ride on the extrusion.
I am experiencing inconsistent depth of cut on my first projects.
Belt tension — the Z-axis should be guitar string tight (but careful not to bend the motor shaft): http://docs.carbide3d.com/assembly/shapeoko/xxl/step-5-belting/ on deep cuts it may help to remove one spring from the Z-axis temporarily, esp. if one hasn’t added a spoilboard on top of the wasteboard — it also helps to install the router as low as possible (installing the Makita adapter upside down will help). Some folks have found it helps to remove the M4 Z-axis tension bolt, apply a thin bead of threadlock along the length of the threads, then reinstalling it after it has dried.
Thanks so much, definitely needs some v wheel adjustments.
Guitar string
:I am not trying to be a smart Alec but:
nylon?
steel string: electric or acoustic tensions different.
which string: Low E, A, D, G, B, highE???
all very different
Just says for it to snap?? in instructions??? If it were a auto fan belt it would be probably 1/2 inch or less easy deflection
did all the adjustments and the same project is great it seems. Most of the wheels were either too tight or too loose. Also, I noticed the Dewalt 611 i got has a rather sloppy 1/4 collet and it seems to need a lot of kind of sloppy tightening without a clear end point. My collet actually loosened up at one point today, glad I found that, was wondering why the cut was shallower and shallower
