Anyone have this in fusion or solidworks?
Are you talking the one with the rims on the two side edges? I believe that is made from a flat sheet and bent using a break. You could mill it up, I suppose, but you’d have to hog out a ton of material to get those flanges. Or maybe mill up counter-sunk holes in strips and tapped holes in the plate and make a laminated structure?
Watcha thinking exactly?
The Wiki has STL files for the new Z -
https://www.shapeoko.com/wiki/index.php/Shapeoko_3#Drawings
I am looking for the PDF for the X plate. I see a picture of the PDF, but not the actual PDF.
