Nomad 883 Pro Dust Head
Where did you get your 50mm hose from for the CT26?
The front door is pretty easy to open when running, even with the Festool turned all the way up. I can tell it has some vacuum, but it doesn’t take much effort at all to open it. My downfall may be using the hose that came with the Festool (I figured after paying $600 on a vacuum cleaner after forking out $$ for the Nomad that I would try to spend as little as possible until I start making some things with it).
I mostly got the Festool to mill PCB after hearing horror stories about the junk that gets thrown around during the process.
Where did you get your 50mm hose for the CT26?
Remember that I design enclosures and vacuum systems for people.
One of the principals is use the largest tubing/piping one can for a long as one can; even so keep the run as short as possible. Another is to avoid bends and when a bend is necessary make it as gentle as possible; also avoid transitions and, when necessary, make them as smooth as possible.
So I went searching the Festool sites to learn of the available tubing options and discovered the largest diameter, shortest tubing they offered:
Pricy, but serious air flow is possible.
That’s not a good sign… :frowning:
Dust collection is about vacuum AND air velocity. We need air speed to get things going and going well. The standard tubing is good but may not be enough (I’ve never tried it). If you look at my enclosure, I have a 2.5" fitting that also happens to fit the 50 mm Festool tubing. Only there does the size drop.
Avoiding bends is also important. When necessary we want then as gentle as possible.
There are definitely issues with smaller tubing and good dust collection. If you did go for a custom enclosure, we can discuss a modification to use larger tubing. Without the constraint of the Nomad enclosure, more options become available.
Garolite and FR4 produce some of the nasty stuff that affects for your lungs. It’s really important to handle it properly.
You’re mostly there! A few tweaks…
mark
P.S.
If you run the tubing out the front and make it as straight as you can, does this affects things? If so, how much?
P.P.S.
You can find pictures of the fittings I use and how I run things through my enclosure here:
50 mm hose has been ordered. I’ll let you know how things go with the larger hose!
Notice the difference between the two tubing choices. The 50 mm tubing is essentially twice the diameter and half the length of the standard one. This reduces air friction considerably.
The diameter of the tubing inside the Nomad enclosure was chosen to be the largest that could easily fit and have sufficient flexibility. It is a tradeoff; it’s always a tradeoff.
With my alternative enclosure, it’s possible to alter the dust head design slightly and use even larger tubing. This is because I have the height to enter from the side and have a very short run (I could have come from the top; personal choice).
Lofting is a complex combination of vacuum (how hard the pull is) and velocity (how fast the air can be made to move). The Festool has plenty of both, it just has to get to the job site.
mark
Also, looking at your photo, you want to eliminate that near 90° right at the dust head. All hard angles are generally bad.
This is one of the reasons I went with my own enclosure… I had much more freedom to run the tubing and avoid hard angles. The Nomad 883 Pro enclosure is very tight when tubing is introduced. The original Nomad 883 enclosure was much more forgiving.
They sure are. I posted a summary of the rules for running vacuum tubing here:
mark
Quick update…I received the larger 50 mm hose and installed it. Since it is much stiffer at the end I had to make a small change to the entry to the Nomad. I’m still going through the same hole but I’m essentially elbowing a little through the smaller hose (same as used inside the Nomad enclosure) so that I can attach the 50 mm Festool hose along the back X axis of the enclosure.
The suction is WAY more present when using the fatter hose (I’m pretty sure this thing could suck my face off at full power) but I’m displeased with the amount of vacuum inside of the Nomad. My plan now is to apply some foam strips along the door to help seal things up a bit more. The gap on the sides of the front door of the Nomad are way too wide IMO.
That’s because you have a Festool running with nearly optimal tubing. No surprise! This is a seriously effective tool.
The standard hose is design to handle to dust flow from sanders, rotary saws and some such. The Festool chopper tool uses larger tubing (37 mm) since it generates dust more quickly. The 50 mm tubing is used when one has to go long distances but for our purposes it’s just perfect - minimal frictional forces.
Let’s examine that.
Remember that air in must equal air out. The Festool is pulling out. That much air must be pulled in. Sealing up the Nomad enclosure is a good idea - it minimizes places where particles can leak out of the enclosure - but you’ve got to let air in otherwise the efficiency of the Festool will drop.
Sharp bends really affect the efficiency of tubing for vacuum purposes. Could you please try an experiment? Run the tubing out the front with the door open and hold the tubing so that is has as gentle a curve as you can work out. Does that help?
We should also look at your transition. It may be leaking or be abrupt, leading to friction.
One of the reasons I gave up on the Nomad enclosure was the need for tight turns.
While I’m getting good performance, there is room for later improvements if necessary - larger tubing inside the enclosure (which would require an update the dust head).
mark
P.S.
Review the principals for vacuum tubing runs here:
Late to this party, but just wanted to add my experience that I also had the smaller Festool hose and even independently came up with the same connector (the rubber flexible hose fitting with double hose clamps thing), so our setups are functionally identical (I have the CT midi). And I did notice that the festool hose by itself with the midi set to full power had quite strong suction, but with the hose plugged into the flexible hose fitting and then into the tubing that goes into the nomad and into the dusthead, that the suction was markedly decreased (the small hose -> larger pipe fitting -> fairly small festool hose opening must be really bad for maintaining airflow).
Nevertheless I was extremely impressed with how well it picked up stuff. With wood or plastic I would say it’s sucking up 99% of everything; like I rarely have to clean anything up - just remove the piece and it’s good to go.
So there must be something else in your setup that is decreasing the effectiveness. Maybe that hard angle right at the dust head? Oh, also I have the regular nomad, not the pro, so had space to make a full circle with the brush instead of just a semicircle. Not sure if that matters.
I like “mbellon” Mark Bellon’s design so much that I took it and made some slight modifications to it for my simple liking. It’s not better, maybe a little worse but definitely different in a few ways. I didn’t create a new thread since this is his work and he deserves all credit. Here are the variances and why:
  1. First I changed the Meshcam design to a “Carbide Create” since I’m using a 4K display on Windows and Meshcam isn’t formatted for that yet (everything is 1/4th the size). Plus I wanted to see what the Carbide Create program could do.
  2. I wanted a camera up close that I could stream to my Android phone and monitor the flow or problems. I know there are IOS apps that can do the same I just don’t know which ones.
  3. I wanted to have a little more suction around the plastic and brass that I have been milling. To do this I felt that a rounder dust shroud, that got closer to the cnc bit, would be necessary along with utilizing harder rubber/plastic instead of the bristle brush approach might work.
  4. I utilized a thinner plastic since it was free from Tap Plastics. The guy gave me the scrap since he knew I’d be back to buy more stuff. The piece was 8x8 inches and .18" thick instead of .5" which both parts top and bottom could be cut from the one scrap.
  5. Last I changed the size of magnets only because I already had some that were strong but no where near as good as Mark’s ones.
  6. The hole for the CNC head is exactly the right size on the top frame assembly to slip on snuggly and stay put. As such, I did not create the two parts that hold the top plate in place as Mark has created. The holes are there so if I need to add that in at a later time, they’re available.
Carbide Create is buggy as hell so I apologize now for imperfections from the top plate to the lower plate, cnc bit selections, RPM’s, etc. I really had to keep at it before I could actually complete the two jobs.
Parts I used:
  • 1 scrap plastic from “Tap Plastics” 8x8x.18"
  • Four neodymium rare earth magnets (I already owned)
  • Flexible sump discharge hose kit from Home Depot (24ft for less than $13!!)
  • Floor walk way runner from Home Depot (I believe $2.28 a foot, you only need one)
  • I bought screws but never needed them since it’s an exact fit (may need it down the line)
  • DBPOWER 2MP USB Waterproof Hd 6-led $23.89 from Amazon for the longer 7M version
  • Free YawCam software for Windows (other formats may exist but I did not check)
  • Free Android IPCam Viewer and/or free Android tinyCam software as a viewer
The finished product. The USB camera has adjustable LED lights on it too. Really nice.
The top and removable parts cut from the same piece of scrap. Notice that the removable part is open to allow slipping on/off with ease
The Flexible Sump Discharge Hose Kit for Under $12 at Home Depot
The plastic rug runner from Home Depot. I believe it was $2.28 per foot. You only need one.
The plastic runner cut up and glued to the removable plate.
Manually cut hole for USB camera (started with small drill bit and graduated to the correct size)
View from freely available YawCam which allows streaming to smartphones, tablets, websites, etc.
Viewing the stream on my Android phone with the freely available tinyCam
The Carbide Create files:
Carbide Create-Dust head.zip (194.9 KB)
Sorry such a long post
VERY NICE!
Skirts vs. brushes is an eternal argument. I remain unconvinced that one works better than the other. YMMV. Please report back on effectiveness.
Can we see pictures of your hose enclosure exit method?
The “close up” camera is nice!
When the machine really gets moving during a job, please report back about the need for the spindle brackets. I found I needed them to ensure that the dust head did not move or rotate and potentially jam the Nomad. YMMV.
There is nothing special about the spindle brackets, they can be machined or 3D printed.
Please report back about how effectively the magnets keep things in place when things really get moving. The double hole method I use prevents easy rotation of the brush plate.
What dust collector are you using?
Please edit your posting with the files. Do not do that! Remove them from the posting. We don’t want people surprised by extensions that don’t match the file contents. Try using a ZIP file.
mark
P.S.
I considered using CC for the fixed and brush plates… but it was so buggy at the time - and lacked construction tabs - that I couldn’t make it work. All Nomad 883 users have MeshCAM and so the choice was made (at the time).
Thanks so much Mark,
I really appreciate the feedback and help. I’m very new to the world of fabrication and am very slowly learning. Your dust collector was an inspiration and a way to learn more so I went with it.
I followed your advice and deleted the secondary post and then edited the first one instead. The forum will not accept uploads of any compressed format (ZIP, 7z, LHA, RAR, etc) as well as the original file format of .c2d so unfortunately I don’t see a work around at this point.
For the “spindle brackets” not being in place I have done a few jobs without any problems using brass and plastic. The jobs have been very short stock with .4" being the largest today. The vacuum hose that comes into the top plate actually extends past the top plate and catches on the lower removable plate. This creates a situation where the removable plate never is able to move into the Nomad’s bracket as the head moves up and down. Hope that makes sense.
Skirts vs. brushes I believe you and have not one bit of clue which one would truthfully be better. I was just hoping that more of the suction would be forced to come through the back opening forcing more debris inward.
The dust collector is simply a shark vacuum with hepa filter. It will do until I can afford anything nicer. In fact the part that feeds into the back is just for show at the moment as I’m really feeding out the front almost directly to the vacuum. I need to make another run to the store to get a 1 1/4" hose to 1 1/4" hose connector. Right now it’s just packing tape bridging the two. :frowning:
Good design comes from initial experience, an openness to outside input and willingness to experiment. The dust head is the result of MANY prototypes. Most of them never left the drawing or CAD stage! More than a handful were machined and tried.
If I can offer any advise it’s learn to sketch (and/or CAD)! If you can see a dragon, you can slay it.
Take your time choosing projects. They should be inspiring (I WANT THAT!) and seem like they are bit more than you know how to do, strive and let necessity be the mother of invention. Rinse. Repeat. Fail. Try again. Succeed.
Thank you! I wanted one for myself and as my friend Tim can tell you, I went nuts going back and forth until I finally found a way to do what I needed and yet had a project that was simple (so I could share it). As Einstein observed, a theory should be as simple as possible - and no simpler!
The differences between the Nomad 883 and 883 Pro are very favorable for machining but made the design very different for a dust head.
We don’t want people downloading files and based on the extension have software do weird things. Thanks for fixing that.
No ZIP files? I have to check that out.
… Hope that makes sense.
Yes, it does. Keep an eye on it. If the dust head rotates, the Nomad can jam - not good.
As I said, it’s an eternal battle. Different camps love their method and claim things work well. I’ve used both and am convinced there isn’t too much of a difference… but I find the brush a bit better. YMMV. Your reasoning is sound… but the physics is complex and surprises abound.
That’s sufficient.
I understand. Been there. Done that. :slight_smile:
That’s fine for the non-friable materials. For friable (“easily crumbed”) materials (e.g. wood, MDF, FR4, Garolite, Fiberglass, carbon composite), one wants the enclosure closed so that the vacuum creates a negative pressure and this keeps the nasty particles inside the enclosure.
I will not share the monstrosity I used for my early tests… I understand. :joy:
mark
Thanks Mark! Good information and thanks for helping me personally.
This WAS my usual mess working with a single plastic print job. Kiss those days goodbye.
Hey! That could be a picture of my machine when I milled the dust head! :slight_smile:
mark
I’m running a HDPE job now with the dust head, the Festool CT26, the 50 mm external tubing and 1.5" internal tubing. I’m going essentially 100% pickup running the CT26 at full blast.
I’ve got a nice negative pressure on the enclosure too - perfect for friable materials!
Have you had a chance to experiment with more gentle curves and an improved transition?
mark
I ran a small job that I designed a while back (before my Nomad arrived) two nights ago and used the CT26 running at ~80%. The material was one of the free Home Depot flooring samples…so plastic. Probably not the best material to test with…shavings were a little big and while some were sucked up immediately, others just joined a growing pool near the Nomad bed.
I did play around with the front cover, opening it a little and then closing it a little…so I have a better idea of the air needed for the vacuum now. I need to work on getting the 50 mm hose a tad closer to the rear. My desk isn’t much deeper than the depth of the Nomad, so that’s why I was curious about the angled fitting for the transition between tubing. I think what I have now is good (nowhere near a right angle), but for my testing I just left it longer than was needed.
Inside the Nomad is a little bit of an issue. I can’t seem to figure out any way to take out the sharp angle leading to the dust head. When at left, there is so little room that it can’t help but be angled because I have to leave enough tubing inside the Nomad to stretch to the other side when closest to the measuring pin.
I’m convinced that a custom case is the way to go, I just have no idea when I’ll get around to that. I wish the Nomad’s case didn’t angle on the front and was boxy like the Carvey (https://www.inventables.com/technologies/carvey).
The Nomad 883 had considerably more room inside. You can see this in the @patofoto pictures. The Nomad 883 Pro has many improvements that increase its stability and quality, decreased part count,
and it easier to machine (create).
I was very happy about those improvements! Then I also discovered that the enclosure was much smaller! @patofoto can tell that I went nuts for weeks trying different schemes trying to use the Nomad 883 Pro enclosure. I gave up. There may be a solution… but I didn’t see it and see don;t see it.
The tight curve of the tubing inside the enclosure is almost definitely the remaining issue. A custom enclosure can solve that issue. I’ll be happy to help you with enclosure design. My solution was to increase the the width and depth slightly and raise the height by 6+ inches. The additional height allows the tubing to enter from the right front, near the top and gently curve down to the dust head.
mark
We just added c2d and zip to the allowed file list in the forum so it should work now. By default, the software doesn’t allow much so we’ve been adding additional file types as needed.
Also, shoot an email to support with your Carbide Create bugs. We’ll do what we can to get them taken care of.
-Rob
when i load the STL file for the spindle bracket it shows stock dimensions as 1" x 1.25 " y and 1" z.
is that correct ? also how to define the red supports ? can you post your support and define stock screens in meshcam.
also the other parts show 4" and 5.25" instead of 6.25" and 5.25"
thanks
