Just got my Nomad Pro, updated the firmware to 1.1 and tried to home it. It crashes to the right side of the machine even though the limit switch is there.
Is there something I should have done after updating the firmware? I would appreciate your help.
Open a log in Carbide Motion (Settings > Open Log) , then press “Send Config Data” and watch the log to make sure the settings are getting updated.
Try homing again (the last setting to be updated will be $132)
They’re tough little machines — should be fine. If not, let us know at support@carbide3d.com
Similarly, please send an e-mail in to support@carbide3d.com and we’ll make suitable arrangements. In the meanwhile, per http://docs.carbide3d.com/software-faq/meshcam-updates/you can d/l the software from: http://www.grzsoftware.com/dl/ and use v6 as a time-limited demo until you get your code. If you wish to try the beta of v7, then it has a facility where one registers it to use with a Nomad and that’s all the licensing necessary.
Any other advice about getting the 1.1 firmware to work? Any settings that I need to worry about so the head doesn’t crash?
Also, something you may be interested to know:
When I first got the machine (before I turned it on) I noticed that there was something in the lubricant near the X-axis rod. It was half of the tip of a screw! The little screw was broken in half, probably during manufacturing or shipping. I had a replacement screw so I changed it. I can send you a photo if you like. The corners of the PTFE sides are also a little squished (I guess also during shipping).
