First time using my Nomad 883 Pro, going through the homing sequence. I have Carbide Motion V4 installed.
The Z and Y axis home fine, but the gantry moves to the left (side without a limit switch) instead of the right, and crashes into the side of the machine. Typing $23=1 fixed the problem, and now my homing sequence runs complete, with the spindle stopping in the middle of the machine after hitting all 3 limit switches. My new problem is that now when preforming the tool-depth automation, the gantry still travels left instead of right, and crashes into the machine then.
Any ideas on what I can try to change, or potential work arounds?
What are your direction mask settings? ($3 in the GRBL configuration)
If you don’t know how to get this, you need a terminal program (like putty). I think the com settings are 115200bPS, 8-N-1. Type $$ to get the settings. As you are GRBL 1.1, you need the cheat-sheet for what the descriptions are. Prior GRBL had it in the response, but memory limitations required the removal of the text in 1.1
