Official Carbide 3D Touch Probe in the Wild
(Luke) #1
Morning all
Following on from a number posts, questions and a few months of waiting a production level Touch Probe has entered the wild!
I won a probe as part of one of Carbides 3D design competitions. Firstly a big thank you to Carbide 3D for the probe and a big thank you to those who voted for my designs. I’m thrilled to bits to trial it.
I don’t work for Carbide 3D and don’t know when the Probs will be available to buy - but I assume it will be very shortly. I will do my best to answer any and all questions I can.
Here is a short unboxing video:
A first testing video is coming shortly.
The setup instructions can be found here:
Please note at present there don’t seem to be any instructions on the croc clip - but this needs to be connected to a machine ground i.e. the S3 frame.
The user instructions can be found here:
Please release probe for sale!
(Adam X) #2
Nice! Thanks for sharing! Looks like a solid product. Probably superior to my alligator clips, electrical tape and tin-foil approach :open_mouth:
Also nice to have the use of the “Reserved” headers illuminated… oh the possibilities!
(Reiner) #3
Is this a pure Z axis probe or is there a possibility to also probe X/Y with it by driving against it from the side?
(Luke) #4
It’s XYZ all at once or X/Y/Z independently - so all three axis.
(Reiner) #5
Nice! I hope it will also work with my Sparkfun Edition controller board.
(Craig Cole) #6
Sweet!! The big question remains… When will it be available??
(William Adams) #7
It should work with the Sparkfun board — all the connections are broken out on it as pins, so it should be easy, but someone will need to puzzle out or document what connects where. @Jorge ?
(Luke) #8
Here is a quick view of how I have set it up on my S3
Apologies for the shaky camera
(Luke) #9
Probing test!
I love this thing
Here is how quick you can find datum! This is awesome.
After playing with it, I do believe there is a offset on the datum X/Y - this is half the bits diameter - if you are using a 1/4 bit there will be a 1/8 offset. Depending on the work you are using you are doing you can program in this off-set if it’s needed.
Also I thought it would be fitting as this was won in an accessory contest to make an accessory for it!
Plans for fusion 360 and Carbide Create shortly.
Probe release info?
(Idan) #10
I’m curious why the interface doesn’t allow taking as input the tool size? What if I’m using non-Carbide3D tools?
(Luke) #11
Whilst I sway towards agreeing it’s not overly difficult to calculating the offset required.
I guess if they had every dimension bit under the sun they’d have a very large list.
(Temujin Kuechle) #12
I needed one 2 months ago.
Let me get this straight, I will also need to upgrade the controller PCB (flash it) and use a newer version of CM?
Thanks!
(Temujin Kuechle) #13
I’m thinking that the list would be relatively short. There are metric and inch size end mills, and there are several standard sizes in both directions.
Maybe, there could be a way to add to this list? Maybe, copy and modify an existing end mill size?
Share these custom settings online somewhere?
And save them too, like in a library (folder) on ones computer/network.
(Luke) #14
Perhaps it will be a feature they add - I don’t know what plans they have. At present they only support 1/4, 1/8, 1/16.
Its easy enough to compensate using an offset.
(Idan) #15
Just let the user type in the size. They must have had a reason not to do it this way (doubt it’s technical).
(Luke) #16
Very logical, a great idea.
(John Werth) #17
Makes me wonder how how you’d use it with a tapered ball end. I guess you could run XYZ with a calibrated blank the same diameter as the shaft of the end mill to get a proper XY than replace the blank with the tapered end mill and run Z. Adds a little extra effort to the process but not anything major.
(John Mayhew) #18
So are these available to the public yet, or are they still in a beta test period?
(Luke) #19
I imagine very shortly.
@gixxergreko - unsure at the moment there are only ball and straight bit’s in carbide motion at present.
(Temujin Kuechle) #20
A tapered ball end mill is usually a standard size at the depth of its radius (i.e. 1/16, 1/8, 1/4, 4mm, etc.). So, in this case, one only needs to move a tapered mill that radius distance in the -Z direction to perform a touch off for the remaining X and Y. But if the script defaults go to far in the -Z direction, then it will definitely be an issue for tapered cutters.
Are ther non-ball end mills?
