Pause, Jog to different pos., then resume from last
In Carbide Motion:
Is there a way to pause in the middle of a job, jog to a place so that you can inspect the tool, and then resume where you left off?
If you pause it will lift up to safety height out of the cut. You don’t get control for jogging though.
If you note the current line number you can quit, edit the file, and then send the balance of it as noted at: https://wiki.shapeoko.com/index.php/FAQ#Continuing_a_cut_which_is_interrupted
