Peck drilling supported?
Does CM4 support Peck drilling tool paths ? I programmed this type of tools path into a VCP job but CM4 just drilled to the full depth with no pecking
Is VCP == Vcarve Pro?
I have some post processors for you to try.
Yes v carve pro. I currently use the shapeoko post processor
Do you know how to add post processors?
Go to File–>Open Application Data Folder…
Open the PostP folder, and add the files here:
DWELL.zip (4.6 KB)
I included Shapeoko and generic grbl.
Use that one when you save your gcode.
You may have to restart V-Carve for it to show up in the list.
The built in post processors didn’t support the dwell gcode.
Do you mean the codes for
Q Peck increment in canned cycles
G81 Canned drilling cycle
G83 Deep hole drilling canned cycle
No, those aren’t supported by Grbl. You can either use a pre-processor which will convert those commands into discrete commands or use a CAM tool and post-processor which will make the discrete commands — MakerCAM is one such option.
It’s better to avoid drilling though — the machine isn’t rigid enough for that in any but the softest of materials — use a pocket toolpath — it’s also better for chip clearance.
@Ton80 I was thinking about something else when I replied. The peck drilling in Vcarve should work without the dwell anyway. Can you get a screenshot of your toolpath settings in Vcarve?
Check your pass depth for the tool, that is what controls peck in V-Carve.
So if you are drilling a .500" hole and your pass depth on the drill bit is.25" it will peck twice.
Thanks… I was only experimenting with the function. I don’t have any real need to use the drill function so I think I will just follow Will’s advice and create any holes I need as pocket paths.
