Pocket carving around letters for raised effect
So I am trying to keep the text and border raised.
Is that an outline font? If you use an outline font, then only the outline will be left as an island, the central part of the text will be cut as a pocket as well.
If not, you need to select the inner border (youā€™ll need two though only one is shown below) as well when assigning the toolpath, and you need to use a Pocket, not an Outside, Inside, or No Offset path. See attached:
rb_pocket.c2d (3.4 KB)
Please post the .c2d file, or the SVG.
Jamie, it looks like the letters are outlined (they have two lines defining them). They should only have one line defining their shapes.
I donā€™t know just how large your project is but I think those smaller letters on the bottom may prove impossible to have ā€˜raisedā€™ like the larger ones. Raising the bottom inside frame line to enclose those letters then v-carving them is a more likely method.
Looking more closely at the file, I believe that the appearance of an outline is caused by an outside profile toolpath.
Iā€™ll try to work up a step-by-step tutorial for this during my lunch break or this evening when I get home.
Hereā€™s a screen shot of what I meant about the smaller letters being V-carved inside the frame ā€¦
To get the larger letters to be ā€˜islandsā€™ within the frame first select the inside frame line then also select the letter shapes then choose the pocket option in the toolpaths menu.
May not help here, but relatedā€¦ a technique I use all the time is to use a V bit on a normal tool path (not a V-carve). If you set the path ā€œno offsetā€ with a V bit (prior to doing a pocket or profile cut set to ā€œoutsideā€ or ā€œinsideā€) at just a few hundredths will make a nice bevel around the whole path without ANY additional file setup work.
I also find that using this technique at even 1/100" just to ā€œscoreā€ the tool path helps prevent some material shredding on the surface around the path that youā€™d get going straight in with a square end mill.
So I wanted to share this in hopes that someone may could still help with this subject/topic. Pocketing around Raised Letters. Iā€™m having issues with bits still being left, even after running sims with 1/16 bit that I donā€™t even own, but I still ran it to see if it would help. So Iā€™m wondering if the fonts in my design are just not the right fonts or are the too close? I didnā€™t know that Iā€™d have to treat the lettering with such special care, but if thatā€™s the name of the game, I can adjust. Iā€™m hoping maybe I just have some settings wrong instead of my fonts. Sample4Help.c2d (1.1 MB) Sample4Help.nc (2.6 MB)
I would suggest looking into Advanced Vcarving with the Pocket clearing enabled (youā€™ll need a BitSetter or some way to ensure consistent endmill stickout at tool changes).
V carving doesnā€™t have the requirement that the narrowest area be 10% wider than the endmill diameter which is the problem I suspect youā€™re having (couldnā€™t really tell from your file since it uses fonts I donā€™t have on my computer).
But with this advanced vcarving, doesnā€™t that only work for the V Bit? Iā€™m actully trying to clear space with the endmill right? That bitsetter thingy is out of my recently Burnt To A Crisp - Budget :cry: :sob:
To do this manually see:
Thank you. I will study this
