Position readout after homing
Hi All,
After homing my Shapeoko 3 the position readout display on the left of the screen reads the following in metric.
X 297.98
Y 133.0
Z 35.72
Is this correct ? Confused by what I’m reading in the " Working with homing ". Practicing the tool change routine.
Confused :confounded:
That’s in relation to your last 0,0,0 location from your last job. That’s why you clear offsets in that window unless you a rerunning the same job or loading a new tool for the same job.
Hi,
Carl, Thanks ! I see what you are saying and will do so on next practice run.
Brian
