Looks dang fine to me! I’ve always wondered what the sound is like from one of these.
Thanks for the heads up! Will definitely bear this in mind
Also, to ease assembly, I’d suggest creating some interlocking notching to keep the pieces from sliding around on you during glue-up.
In order to do this well with thin plywood sheet stock, you may just want to route in slots that you could stick square dowel pins in that could engage both pieces, if you don’t want to do an interlocking digit pattern (to keep a clean straight outside edge).
I’m going to make a jig for the glue up to hold everything in place
Also a good move—but that won’t add to overall structural integrity of the end product, whereas moving from butt-joints to something that gives you more physical interlock will
I always try to make everything I make a bit drop-resistant, on the expectation that I will butter-fingers it at some point.
Think blind finger joints
Blind joint notches and pegs will also help line up the pieces, but you have to be careful in thinking about assembly. in a simple box, 90 degrees are all easy to do, but you will need to be careful about how you put in your last piece(s). If you do a glue-up all at once and don’t use CA glue you should be ok.
UPDATE 1:
Materials, Prototyping and Jigs:
As for many of my projects I am using white oak as the material. It is a beautiful wood which I get as off-cuts from a local hardwood flooring company. They kindly let me sort through their huge pile of off-cuts when I explained my project to them, sooo thanks West Sussex Antique Timber Company!
I cut the long boards into lengths of about 400mm and paired them up with other similar boards so I could glue them together using the tongue and groove joints already cut into the floor boards. Some ended up flatter than others and there were some gaps but this shouldn’t be an issue. (Nothing a bit of sanding and filler can fix!!)
I milled a test of the hedral shape that makes up the dodecahedron out of mdf to test the fit of the speaker. It may not be very clear in the picture above but the hole cutout for the speaker was about 2mm over sized so I adjusted my CAD model accordingly.
MeshCAM did something weird on the recess for the speaker. It cut a small slot around the perimeter of the speaker recess for some reason. It thought it may have been Z-axis slippage but it was the correct depth. The rest of that recess was not cut out all the way for some reason… I thought the pencil finish was supposed to cut this but it didn’t for some reason… I am going to use Aspire for machining the oak parts as I am more familiar with it and it is reliable for me. My plan was to use Carbide Create but I couldn’t get my dxfs from Fusion to open in CC for some reason?!
This anomaly with MeshCAM did remind me that there is a lip around the edge of the speakers I have which means the rubber edge of the cone won’t sit inside the hole as I wanted it to. So for the final parts I will mill a slot to allow the speaker to sit flat.
Jigs:
I designed two main jigs to be used whilst building his project.
The first of these is my glue up jig. It is essentially a sturdy MDF frame of the angle that the hedrals need to be glued to each other at. I will make two of these so that I can clamp the pieces between them whilst the glue dries.
The second jig is for my mitre saw. To cut the chamfers that allow the hedrals to fit seamlessly together I was going 3D machine it but that would take too long according to some tests I did in MechCAM. So I am going to use a compound mitre saw to cut these angles. This jig helps line the pieces up to cut the angles on all sides of the hedral fairly reliably.
Quick update:
Making some progress and doing the first glue ups
Only just realising how big this thing is going to be when all 12 hedrals come together! (banana for scale)
Edges are going to need some filler and a lot of sanding! my mitre saw isn’t very accurate…
I have also been working on designing a stand for the speaker. I wanted to use copper pipe because it goes really well with the white oak of the speaker. This is my initial idea and I would love some feedback!
Also, if anyone knows how to align these two parts so the speaker sits in the stand so I can render some photos and an animation I would be grateful for some help!
Final Update:
Sorry I have been so bad at documenting this build on here but I have been making good progress and thought I would save it all for the video that is coming soon
I encountered an issue whilst making the base that I think the Shapeoko can solve perfectly!
The copper pipe base consists of two triangles which need 60 degree cuts on the ends of the copper pipe to create a nice solder-able joint. Unfortunately I don’t have a mitre saw that can cut that angle so I thought why not do it on the CNC!
I came up with a simple jig that the copper pipe can sit snuggly in and be clamped in place if needs be. I can then run a simple follow path job on the cnc that can cut the end at a a perfect 60 degree angle!
The trick will be getting he jig the right size so that the copper pipe sits tightly enough inside. I’m going to try this out tomorrow and see what happens!
If it were me, I would make the fixture a bit longer so that both ends are cut without removing the part, and, to hold the part in place, cut the groove a little wide and use a dowel about 1/2 the part diameter laid on top between the part and one side of the groove to wedge the part down and against the other side. A screw into the base and a washer large enough to grab the dowel (or, if you want to go fancy, a finger type hold down) apply down force to the dowel.
Yes that would work for the smaller bits but I also have to cut the chamfer on pipes that are about 700mm long so it wouldn’t work for those bits!
That clamping idea sounds interesting, might try it!
That looks SWEET!
It looks absolutely fantastic. Great job!
Now I guess the obvious question is, how good does it sound? And, are you going to stain and clear coat the wood, or just leave it au naturel?
Thanks!
I haven’t actually tested the sound quality yet but I don’t think it will be amazing, the drivers aren’t great quality!
Just going to use a wipe on light stain to bring the grain out
I love this project. I get excited every time I see you’ve updated the thread. Can’t wait for the video! Thanks for sharing this!
Thank you! It means a lot! Just editing it together right now
