Prop-Nut project for keepin' it cool
Corian is mostly Acrylic/Acrylate-based resins, with fillers depending on what the “look” is the designer was going for… so as a result you can treat it mostly like Acrylic and then tune from there based on how some test cuts turn out. Machines pretty cleanly if the variety you’re working with doesn’t have too many large chunks of different coloration in the fill. Good luck!
