Repair parts: the Red Emergency button
(Troy Meyers) #1
The red button fell off the Emergency switch on my original (v1, not “Pro”) when I had to whack it. It’s broken, not just unsnapped. Does Carbide3D have replacement parts, or is anyone familiar with a source?
(mikep) #2
contact them at support@carbide3d.com and see what they can do. They’re pretty good about this stuff.
(Troy Meyers) #3
Thanks, will do!
Blah Blah (post had to be at least 20 char)
(Craig) #4
Are you able to twist the knob back on? Looks to be a bayonet mount.
(Troy Meyers) #5
No, it is quite broken off. The bayonet - like features are intended to require a twist of the button to release it back out when the emergency is over. The shaft broke in this case.
(system) #6
