Retract hight and setting zero
Greetings!
After finally getting my feet really wet, I have some questions about retract hight and setting zero at the bottom of the stock.
First: Where do the retract hight measure from? Always from zero or is it from the top of the stock regardless of zero at the top or bottom?
Second: If zero is set to bottom of stock, would you need to take that into account when setting cut depths? I.E negative values? I want to set zero at the bottom and set the stock hight to slightly higher than the actual stock. Then i can run a pocket or facing operation down to a known hight.
Best regards!
Btw… This is soo fun!
Retract is from the top of the stock.
In Carbide Create (and I’d imagine most other software), the adjustment for depth of cut is automatically calculated from the declared origin and the stock thickness.
Hi I am no expert but as I know it in fusion 360:
it depends on your model origin and it’s relation to the top, so if your origin is on the bottom and your stock is 20mm thick it will calculate the retract height to be 0 + 20mm + Retract height if this was 5mm then after correctly zeroing the machine it would retract to 5mm above stock, I was discussing this lastnight with Mikep and other in this post that you might find helpful (Setting Z to bottom of stock not to top )
Again this follows the same theory so if Z is 0 and the origin of the stock was at the top the CAM Function in Fusion 360 calculates that it needs to “+” to the height, if you set the origin to the top then it would minus the value. screenshots to make it clearer . So basically it is all interpreted from your initial sketch and placement of origin (not for this post but further into your workflow you can redefine your origin but that is a little bit more complicated):
Origin set at bottom the value would be plus
origin set at bottom the value would be minus.
Hope this helps
Sherpa
(more experienced people please correct me if I have anything wrong)
I think @Sherpa might be over complicating things. There are a variety of ways of handling this, but Fusion makes it pretty clear with the options in the toolpath “Heights” tab.
All of the settings give a “from” option. Just decide what you want it you mean. Default is from stock top.
Excelent information! I appreciate it wery much. The fusion 360 information will become handy when I start with my 3D ideas to!
