Running a Vcarve pro project Z-Axis grinds then plunges straight down
After reinstalling Carbide Motion v4 I am able to use Carbide Create generated g-code without issue. My only issue now is trying to run any g-code from Vcarve Pro.
I have a Shapeoko3 XXL.
Usually this is caused by a datum or safety/retract height set higher than the machine can move.
Post your file here (or to support@carbide3d.com) if you can’t find it and we’ll do our best to help.
(66705): <- $132=80.000
(66704): <- $131=850.000
(66703): <- $130=845.000
(66702): <- $122=400.000
(66701): <- $121=400.000
(66700): <- $120=400.000
(66699): <- $112=5000.000
(66698): <- $111=5000.000
(66697): <- $110=5000.000
(66696): <- $102=40.000
(66695): <- $101=40.000
(66694): <- $100=40.000
(66693): <- $32=0
(66692): <- $31=0
(66691): <- $30=1000
(66690): <- $27=5.000
(66689): <- $26=25
(66688): <- $25=2000.000
(66687): <- $24=100.000
(66686): <- $23=0
(66685): <- $22=1
(66684): <- $21=0
(66683): <- $20=0
(66682): <- $13=0
(66681): <- $12=0.010
(66680): <- $11=0.020
(66679): <- $10=255
(66678): <- $6=0
(66677): <- $5=0
(66676): <- $4=0
(66675): <- $3=6
(66674): <- $2=0
(66673): <- $1=255
(66672): <- $0=10
That’s your Log / G-Code settings, not the Vectric file or G-Code or setup instructions which were asked for.
This is the gcode file I created to test with…simple pocket with Drillhole.
T1
G17
G21
G0Z88.0008
G0X0.0000Y0.0000S12000M3
G0X0.0000Y0.0000Z20.0000
G1Z-17.9070F254.0
G0Z-12.8270
G1Z-20.0660F254.0
G0Z20.0000
G0Z88.0008
G0X0.0000Y0.0000
M02
Will, I’m good now. The retract and datum were off. I’m good now…thanks.
