Shapeoko 3 z axis issues
(Michael Oakley) #1
Im looking at buying my first cnc Shapeoko 3. I keep reading about z axis issues and the need for the Beaver CNC HDZ upgrade. My projects will involve a lot of z axis contour work.
can someone clarify this?
thanks
(Luke) #2
Michael
I’m Luke - the HDZ builder/designer. I’d say the standard S3 axis is more than suitable for most. Those who upgrade usually want additional Z travel or want to push their machine to the max. Sometimes this will include an upgrade to accommodate larger spindles etc.
Talking myself out of a s sale, the use of the standard Z is more than suitable for most. You might find it an upgrade you do at a later date.
Best,
Luke
(Michael Oakley) #3
how much more z travel does it provide
(Luke) #4
It allows for approx 150mm of Z travel but this shouldn’t be confused with clearance.
It does however allow you to use the full amount of clearance.
(Gary) #5
It’s not needed as much as desired by most. I myself wanted to move up to more power. And with more power comes more weight. I’m now pushing a 3HP spindle that I believe weighs in around 11 pounds. People with a standard z-axis have made it work, but it’s definitely pushing the limits of the stock axis. The Beaver HDZ takes a spindle like a champ without stressing it out. If you want to later get into metal work it will definitely be a plus.
(Gary) #6
Luke,
I think we have become your Minions and are doing your evil bidding for you. LMAO
(Wilbert B Pino) #7
Its a great addition to your Shapeoko. Wont regret it.
Minion%20Loudspeaker
(Luke) #8
I should have put a disclaimer. There is something in the paint :stuck_out_tongue:
