Shapeoko XXL Assembly
(Mauricio Rubio) #1
Good morning:
Finally, I am in the process of assembling Shapeoko XXL. In the assembly manual, there are some points in which I got lost. For example, the springs that are supposedly factory mounted in the Z movement item. However, I got a box with a pair of springs in a plastic bag and since there is no a picture of the place where those springs are mounted in…I dont know what to do.
The process of assembling the machine has been fascinating, because I had to step forward by myself in some points where there is no instruction or graphic description about the procedure.
I beg your help on the springs issue.
Thank you in advance.
(William Adams) #2
Do you have a pre-assembled wiring harness?
If so, you should be using these instructions:
Please let us know of any difficulties you might have, or if you don’t have the pre-assembled harness at
(mark robinson) #3
(Mauricio Rubio) #4
Thank you Will And Mr. Robinson. Looking at the picture, I can see the solution. I also can see that the struder labeled Shapeoko is the x/z rail…and not the right rail as I assembled…
Muchas gracias!!!
