Simulation Shows Wrong Size?
In my latest project the simulation showed much larger than it should although the shape was correct.
Is this a known problem and any solution?
You can see the problem in a video also:
https://youtu.be/UMmPnpNHo3I?t=142
Many thanks.
Carbide Creat has a minimum size for the preview ~3" x 3" if memory serves — just ignore the extra area.
Thanks Will. I guess it’s a “feature” not a bug!!
