Hi there,
Noob question here. After a finished toolpath, i would like it to either finish at current XY + Z offset or just got to Job zero instead of going to Homing. I can’t seem to find a way to do that. any suggestions?
Thanks
Omer
Hi there,
Thanks
Omer
M30 is interpreted by Carbide Motion as lift and move towards the back of the machine — replace it with a move to safe height and you should have the behavior you want.
The vcarve post processor uses the following commands at the end.
G0[ZH]
G0[XH][YH]
M02
I think if I remove the M02 it would raise and move to 0,0 and stop there.
Hmm I see. Is there a guide for G-Code, like a Wiki and/or quick reference in regard to Carbide Motion and how it interprets it? or even a G-Code wiki guide in general?
Thanks
