Spindle hesitates wont turn on
75% through a job the spindle stopped… it hesitaes now and wont terun on
1/4 in bit milling machaine wax. help…
If this is for a Nomad, since the test for verifying spindle functionality is to turn it on, then watch for hesitation I’m going to guess that you probably need a replacement. Please contact support@carbide3d.com and we’ll get that process started.
ok I will get the started William
In the meantime, you might try turning it off (and removing the usb cable), giving it a spin by hand, then plugging usb back in and powering things up. It might get you going. Should still get addressed with support, but might get you through your project.
