Suckit Dust Boot and X axis limit switch
Just got mine yesterday and started install today. Order January 11th, so it took about 2 months. Shipping to the US was one day as they shipped DHL. One thing about DHL is they required signature for delivery, however if you get on their website you can sign and request that it be left at your door without you being present.
Install went pretty good, my limit switch fits tight, but works fine. The one thing I’m having trouble with is crashing into the left hand rail side and can’t remember is how to limit X for in quick jog mode. I searched on here and couldn’t find my answer, or tried what I found and it didn’t work. Think I have to reset the bed size, but couldn’t make it work. I’m on an XXL running CM4 and Grbl 1.1. Anyone have the fix handy?
Thanks,
Dan
To reduce the bed size for the purposes of rapid positioning and soft limits, please see the homing switch installation and configuration instructions: http://docs.carbide3d.com/article/67-shapeoko-3-limit-switch-installation
I think I need to explain this better:
In CM4 you only get the choice of SO3, SO3XL, or SO3XXL for configuration. In my case X of 830 crashes the gantry because my dust boot is slightly wider than the Z plate:
So I went to the MDI window and set X at 800 using $130=800
I then verified this in the log using $$:
And X is indeed set to 800:
Then I try to rapid position using CM4 and Crash!!!
Then I look at the actual position in CM4 and it shows 815 (I hit my Estop button so as not to kill my belt, don’t know if it would have gone further):
I am still a newbie, but this suggests to me that even though the machine knows it has limits, CM4 does not know when to stop and/or it still thinks the bed is wider than it is? Or maybe I lost the plot and just need a nap?
Thanks,
Dan
@DanoInTx Do you have soft limits enabled? $20=1
Yes, tried that and I get the following error:
It really seems as though CM4 has the positions hard coded for Rapid Positioning unless I’m just missing something obvious?
Thanks,
Dan
I believe you’re correct, and that Carbide Motion needs to either read from the soft limits set in Grbl, or make that number in the preferences configurable. @robgrz
Bummer, that means you can’t Center up your rapid moves either. So I can either shelf my Suckit boot until CM4 catches up, or roll back to CM3. I have another really good dust boot, but I was hoping the Suckit with fixed height might solve my Z belt slipping during deep plunge issues(my other boot moves with the Dewalt and I think the bristles foul Z sometimes). I’ll probably roll back to CM3 for now. Is there a simple roll back procedure for Grbl 0.9? Thanks as always,
Dan
I assume someone has requested configurable rapid position coordinates? Or at least a center based on “shapeoko table parameter/2” ?
In CM3 the settings tab allowed one to set the various settings line by line, but CM4 just gives you SO3, XL, XXL. It’s great for a straight standard setup as you can’t really get anything wrong, but from what I gather many of us don’t have bone stock machines so it’s pretty limiting unless we use a different GCode sender. I’ll probably roll back to CM3 for now.
Dan
I finally adjusted my X extents today for CM3 rapid positioning with my relatively new SuckIt boot (now @ 820mm). Interesting to learn this has been deprecated in CM4?
Sent them an email and they were in fact quick to response. Thanks for the suggestion!
@thesignguy Glad to hear it. I finally got an email from them over the weekend. :slight_smile:
I don’t know if it has been depreciated, and it’s a beta release so for all I know there’s gonna be some big change by the time of actual release? I’m not trying to make any money using my machine, so I can hope that this along with some other reported issues (10 key jogging broken, showing wrong/no filename on load screen still as of beta 4.07) will get corrected before it’s a final release. I really like the speed overrides, smooth jogging and other features in CM4 so I hate to roll back to CM3 just to make it work with my setup. Guess we’ll wait and see:)
Dan
Losing the 10-key support is something that needs restoration for Carbide Motion… I use my BT keypad for CM/GRBL and Estlcam all the time. The Estlcam jogging has always been smooth as silk, and CM/GRBL herky-jerky, but can deal with it. It would be nice to see that mitigated.
I’m waiting for more CM/GRBL 1.1 refinements before jumping over.
Just received my SuckIt dust boot today, and was going to install it in the next couple days but if there are issues with CM4 limits then I may have to wait.
Is there any reason the rapid positions are not settable? In a past life, I was an embedded firmware guy and would do everything in my power to have all settings adjustable. I didn’t like to hard code any setting if at all possible.
As long as you avoid the left/western rapid positions CM4/GRBL1.1 I’m certain is in a very usable state… Carbide would not have released it otherwise for the masses.
As a software and electrical designer, I understand the double-edged sword nature of more adjustability vs. simplification with fewer adjustments. Like you @slukas, I always strive to make everything adjustable while at the same time make things almost brainless, or what I like to describe as “buy and fly”.
I’ve had a number of head-scratching “missing feature” moments using the CM/CC suite which I’ve documented in the software suggestion thread that would really improve the workflow and UX, but I digress.
The more users running CM4/GRBL1.1 the better.
I’m in no hurry to upgrade.
ok, after some goofing around with soft limits I can reproduce what’s going on with Dan’s set up. Carbide Motion 407 (what I’m currently using) was working properly. When you first set up $130=800, you did not have soft limits turned on ($20=1, required for using soft limits [$130 through $132]).
Once you turned on soft limits with the command $20=1 at the MDI screen, the command took. When you do a rapid position to NW for example, CM sends [G53X-820.000Y-10.000Z-5.000F6000.0] to the controller telling it to go to [home]-820, which is outside of your $130=800 giving you the error (Jog target is greater than home-800 [your limit], CM trying to go to home-820).
So really, any rapid command from CM that goes all the way west will go to an X of [home]-820. So you will need to keep your $130>=820 to 850 and $131>=780 to 850 (SW rapid sends G53X-820.000Y-780.000Z-5.000F6000.0) if you want all rapid positions to work.
Hope that makes sense…
I suppose that means that the rapid positions need a setting to define the position we want them to travel when clicked (or dynamically generated based on machine size/soft limit
Something like a percentage of the limits…yeah that would make sense.
You can set that in CM3, as far as I can tell CM4 doesn’t care what the Grbl limits are, as far as I can tell they’re hard coded.
Dan
+1 on this. I’ve been running my machine(s) very close to its theoretical limits, and not being able to eke out every last millimeter is a minor frustration.
