Suggestions on Letters
(Delmar Turner) #1
Attached you will see the start of a hand carving. Can someone please offer suggestions on how to get Slopped or rounded edge letters like these started by hand. I use Carbide 3D and Aspire.
(William Adams) #2
Offset the letters by the amount needed to have a V carve toolpath cut that deep, and by half that amount. Select the inner and outer path and do a V carving. Then select the in-between path and an exterior bit of geometry and cut that as a pocket.
I believe Vectric will allow you to just use a V bit and will just cut that if one limits the depth of the V carving.
Here’s how to do it by hand in Carbide Create:
(Stephen Gullage) #3
So you want v-carve letters that stand out rather than cut into the wood, correct? To do that in Aspire, draw a vector around the letters you want to carve. When you select a v-carve toolpath, select the surrounding vector and the letters.
So, this:
Cuts like this:
If you set a flat depth and a flat area clearance tool, you’ll end up with something like this:
(Delmar Turner) #4
Thanks Stephen. This is perfect…
(Delmar Turner) #5
Thanks Max this helps greatly!
(system) #6
