SuperPID-help cutting aluminum?
Also, you want to adjust the speed of the trim router to match the feed rate which you can reasonably achieve so as to get a chip load which is suitable to the material you’re cutting — this often wants a lower speed, rather than a higher. See Tutorial on feeds and speeds (which needs to be expanded upon or finished)
