Over the last few days I’ve been examining the machine, trying to maximize accuracy, and figured I’d post an interesting if not that helpful follow-up to this post.
The original Dewalt router had a tiny bit of bearing knock. It was used (abused) and I had a hardly used one on-hand from my woodworking hobby so I swapped them out.
Finish quality didn’t improve, though, and I really thought it would.
Knowing I was going to be swapping and selling the older/troubled Dewalt on eBay (with full discloser of its problems, of course), I had ordered the Makita. So yesterday I got around to installing said Makita and make a couple of test cuts and got a similarly rough finish.
I was using a CMT 1/8" bit upcut spiral, which is the bit with which I achieved the best finish to this point. But for some reason I decided to swap to a Whiteside bit (not new) and make another test. Wow, a substantial improvement in finish quality. I’m using the same RPM’s as I had been on the Dewalt.
So my theory is that I settled on that CMT bit with the original (bad bearing) Dewalt because it achieve the most accurate results with that router. However, the CMT bit with the good Dewalt router was now the weak link. Unfortunately, I never tried the Whiteside bit with the newer/better Dewalt (I will eventually get around to this).
So, to summarize, swapping parts out has led me to a finish that I find very acceptable. I will likely try an O-flute bit again (was getting poor results in that original Dewalt).
I’m only posting this as inspiration for those that don’t get great results first-time around. I can’t work on this full-time and it does take time to become familiar with the machine. My first CNC router (the K2 prototype) was a tremendous learning curve which has helped in figuring out how to approach this used Shapeoko unit.
I do like the Makita for CNC use quite a bit because it offers both a spindle lock or two-wrench method for tightening the collet. I prefer the two wrenches, just personal preference I guess.
Thankfully my dust shoe design can work with either the Dewalt or the Makita, it was as simple as swapping-out the motors.
