Text carve does not like funky French characters
Hi,
While testing V-carve toolpath on a piece of text, the first letter got left out of the generated toolpath :
The font is Arial - regular.
I guess the toolpath generation algorithm struggles with the cedilla on the initial character, that overlaps the body of the ā€œcā€. If I switch to a different font where the cedilla is attached differently to the character body, sometimes it works fine.
Here is the project file
test_cedilla.c2d (2.4 KB)
Anyway, as a workaround I will be using a different font, but wondered if this was a known issue.
This is a technical choice on the part of the font designer ā€” they can do composite characters as in Arial (where the accents are added as a separate part), or they can unify the outlines as you wish had been done.
You can fix this by doing a Boolean union on the letter and accent.
The boolean union is a good tip, thanks.
