Text will not import from illustrator
(Scott Denny) #1
So I cannot get text to import into create from Adobe illustrator. What am I doing wrong?
(Neil Ferreri) #2
Try converting to a path in Illustrator.
(William Adams) #3
As @neilferreri noted, Carbide Create doesn’t support text objects from SVG files — you’ll need to convert the type to paths which will then import as closed geometry.
(Scott Denny) #4
So I’m an illustrator idiot. How do you do that?
(William Adams) #5
See: https://forums.adobe.com/thread/623030
  • select the text
  • Type | Create Outlines
(Scott Denny) #6
Thank you so much. This helps a ton.
(system) #7
