The mother off all mills for aluminium milling (Nomad)
Folks,
I tested another high end mill and want to share the fantastic results. The geometry is specially designed to lower the cutting force and I gave it a try. I can do DOC of 3mm and stepover of 1,4mm without any chatter on the Nomad. Here are the facts
Mill:
Diameter: 3mm
Shaft: 6mm
Coating: DLC (Diamond Like Coating)
Flutes: 3
F&S:
10000 rpm
250mm/min
stepover: 1,4 mm
DOC: 3 mm
Stickout: 30mm (incl. the 5mm shaft which does not hurt)
Cooling: Low tech air cooling (Fish tank pump), no fluid
Material: AlMgSi 0,5 (6060)
It was just amazing to see, that the cutter really cuts the material like butter. Here are a few pics.
—> A picture of the mill. I generally found out, that a thick shaft increases the performance and offsets the low torque of the Nomad (Physics: Mass that already turns wants to keep turning…and the shaft is a massive increase of mass…)
This is a pocket made with the F&S mentioned above. This is the result of roughing.
Take a look at the chips…quite “massive” for the Nomad :wink:
Short clip of the milling procedure:
https://youtu.be/F3UwIosdGHQ
Best Regards
Markus
Neat, but youtube is saying the video is unavailable.
Fixit please.
Thanks for the hint…fixed, sorry :wink:
Do you have a link to a place where we can order one if we would like?
I wonder how that would perform on brass…
https://www.hoffmann-group.com/DE/de/hom/Monozerspanung/VHM-Fräser/VHM-Fräser-MTC-DLC/p/202270-3
It’s a European Company, don’t know if they deliver to the US, but here is the link
Found the same thing here for 1/3rd the price:
https://www.mscdirect.com/browse/tnpla/55465009?cid=ppc-google-Returning+-+Milling+-+PLA_sK3DOOR05___164128486730_c_S&mkwid=sK3DOOR05|dc&pcrid=164128486730&rd=k&product_id=55465009&gclid=CjwKCAjwo4jOBRBmEiwABWNaMXjHJPKuvdBABaMRrYbBo3DZeyAw53g2b6mOd3gd1ydFJQTfaMbaURoCz8MQAvD_BwE
Except the missing DLC coating :wink:
To be fair, the coatings wear off after the first few minutes…When I was a machinist, we’d get those coated endmills, and they would wear out faster then the uncoated, because they coat the cheaper endmills.
I would suggest you have a serious conversation with your supplier if this is the case :wink:
Folks,
Just finished the part and wanted to share a short clip about the project.
Durability of the mill was great, did the entire roughing with one mill (~5 hours). Coating started to wear down after around 3 hours, but F&S were unchanged until the end with no problems.
https://youtu.be/5tYe5z6B-Dg
Markus
