I wasn’t really to hip on the MDF waste board because of the dust as well as issues with the 2 sided tape pulling free while machining. I had some PVC trim board laying around so I cut out some 8"X8" pieces and drilled them to the wasteboard specs. The great part is that when the waste board starts thinning due to from surfacing operations, I just use the AZEK PVC glue and glue on a new board. The AZEK glue( or you can use regular PVC glue from H.D.) welds the 2 surfaces together. I have had zero issues with the double sided tape pulling free
