Touchplate Redux
(John Ellenberger) #1
I decided to investigate touch plates. Because I have the Shakeoko from Sparkfun with the non-standard controller I was worried about using the “active controllers” like the always-out-of-stock carbide unit.
This fairly recent video seemed to provide a good solution for me (the Sparkfun has two probe screw terminals which accept two wires directly). I don’t see anything in this forum so here is the link:
Shapeoko with ebay probe
He seems to be talking about this (now $39):
CNC Corner Zero finder/Touch Plate/Edge Finder/XYZ origin
Note that the seller lists a much more elaborate configuration routine which I think is because instead of just centering on the hole he is finding the x-y edges of the plate(?)
Anyway I am willing to invest in this. I think I may also buy one of those cheap chinese Z plates for which ebay has about 100 listings–for $3 what could go wrong :wink:
(Neil Ferreri) #2
Here’s the one I made on an XL in Fusion 360.
https://a360.co/2qAxMzh
Drilled and tapped for an M3 screw to make attaching wire easier (I just use an alligator clip).
(Phil Thien) #3
I think that in order to use that hole for centering, you need a macro that might limit which software apps you can use.
I watched the video though and that SourceRabbit g-code sender looks pretty nifty.
