My issue is trying to figure out howto cut such small triangles with no way to secure them. Anyone had any luck with that?
Cutting thin walls for between them wasn’t too hard but being able to cut more than one triangle at a time has me reeling.
@swiftmas
If you level your wasteboard first you can leave a very uniform thin skin on your acrylic parts.
It may take a couple tests to dial it in, but a skin of .002" - .005" is easily cleaned up with an exacto blade.
I like running strips of hot glue underneath the stock. You can cut all the way through as long as you have glue under the area where the pieces will be.
