Upgraded to carbide 4 grbl 1.1 cannot manually set axis size?
(Andy Clancy) #1
Hello all,
I upgraded to carbide 4 grbl 1.1 without issue and ran test OK.
I have a suckit dustboot installed and need to reduce x axis length but using mdi to send $130=820.000 nothing happens?
Any ideas please?
Thanks
(Richard Cournoyer) #2
Let’s start here:
Go to CM> Settings. Open a Log Window. GO back to MDI and type $$. Look at the settings (Hint, Click Stop). What does it say for $130 (in the log)?
(Andy Clancy) #3
I do see the command and the change but when I jog I still hit the rails?
How do I avoid this?
I appreciate your help.
Thank you.
(Richard Cournoyer) #4
Sorry, baby steps, here.
So I assume, that 820mm worked before the 1.1 upgrade?
And for curiosity reasons, is it hitting X+ ® or X- (L-) rail?
(Jim Amos) #5
Andy -
This has been discussed in this thread:
It’s my understanding that when you perform rapid position jogging that Carbide Motion does not use the GRBL extents, so if you can avoid the “left/west” movements you should be good to go with CM4.
(Dan Nelson) #6
As Jim pointed out this is no longer functional with CM407. I just went through same issue and in the end rolled back to CM3 and Grbl 0.9. Hopefully there will be a fix, but in the meantime this is all I found that worked.
Dan
(Andy Clancy) #7
OK
Thank you for your help and advise.
(Scott Conant) #8
Another thing to keep in mind when you are using $130, et al, that you set $20=1. This enables soft limits. The board will drive your cutting head as far as it will go unless you have $20 enabled.
$130, $131, $132 – [X,Y,Z] Max travel, mm
This sets the maximum travel from end to end for each axis in mm. This is only useful if you have soft limits (and homing) enabled, as this is only used by Grbl’s soft limit feature to check if you have exceeded your machine limits with a motion command.
(Andy Clancy) #9
I will give that try Thank you
(Dan Nelson) #10
Posts 10-12 in this thread describe what happened when I messed with soft limits. Unless I’m doing something completely wrong CM407 will over ride the limits set in Grbl, or error out:
This was why I went back to CM3 Grbl 0.9.
Dan
(Scott Conant) #11
I made an in-depth reply here:
(Bo La) #12
How do you change the $20=1? I tried to enter it in MDI and it didn’t work. I have the XXL and my table dimensions are 450 and cannot change it…a
(Scott Conant) #13
Make sure you click on “send” after entering each individual command.
(Bo La) #14
Of course, but it doesn’t seem to work…The soft is beta and it shows…
(Scott Conant) #15
Strange. Open the log and send $$ to the MDI. that would show your settings in the log and verify that $20=1
(John) #16
I need to roll back after upgrade to CM4 - pls tell me what the steps to roll back, where is the link to download grbl v0.9??? pls help
