What are your favorite knob designs?
(Daren Lewis) #1
I need some thru knobs for a project I’ll post in the gallery shortly. What do folks like to do for knobs? Buy? Make your own?
I threw a couple together tonight using 12mm birch ply, short cuts of PVC pipe in counterbores, and threaded inserts. I need to clean these up, but they have the advantage of being really cheap and I can use materials I always have in stock for various thread sizes.
I need to clean these up, but here they are…
(Phil Gorsuch) #2
I have done some knobs myself. It was good practice but ultimately I think if you are doing one or two its not really worth it given the time + material costs. Unless I need something truly special I think I am going back to buying…
(Daren Lewis) #3
Thanks Phil, I tend to agree. I have the materials cost down to about $0.90… but the time cost is much higher. “Truly special” is a great test. Perhaps the reasons are:
  • Truly special
  • Functionally unique and not otherwise available
  • Need it now
  • Just want to play/experiment/learn
(Stephen Gullage) #4
I keep a set like this on hand https://www.amazon.com/POWERTEC-71127-T-Track-Hardware-4-20/dp/B07D4BQXKB/ref=sr_1_11?ie=UTF8&qid=1532718843&sr=8-11&keywords=1%2F4-20+jig+set
(mikep) #5
This one is my favorite, but it’s a bit of an investment of time and material… https://youtu.be/yP9WM21VXDI
Can be done without the dowels which can make it a lot simpler (and doable on a SO with some effort)
In general, knobs aren’t worth the effort, so many, so cheap - check Fastenal.
(system) #6
