I am looking at ways to engrave photos into wood, and one way I think I can achieve it is by converting a photo into something as illustrated in the photo attached. Does anyone know what kind of rendering this is? Closest I can get is halftone, but halftone seems to refers more to dots as opposed to lines.
Also if you can let me know if any program that can convert a photo into the style of the one in the link, I would appreciate it.
Thanks. I tried the program. managed to get a halftone line image I want, but when I import it to Carbide Create, it appears different, were only the outlines of the lines are illustrated (i.e instead of a circle, a letter O is visible).
Is this normal? Which tool should I used? v-carve?
Also, it seems to be taking up a lot of resources (both in Create and Fusion 360) from what I imagined is a simple drawing. Am I doing anything wrong in rendering it in the app?
In Adobe Illustrator special effects and so forth may need to be expanded / converted into discrete objects in order to export so as to allow Carbide Create to import.
Or, it may be that you’re using a program which creates a G-Code file ready to machine using Carbide Motion — in that case, use a tool such as Camotics to preview/verify it.
I couldn’t find support online for the program. Hoping I could ask here. Halftoner 1.7 has no provision for entering tool information, so I don’t know how it creates gcode without taking this into account. Closest I see is Tool Angle, which I suspect is the angle of the approach of the tool, but perhaps it could me the angle on a v-bit? Even then it does not know how thick the endmill will be.
V endmills only have a max diameter — if the program doesn’t allow it to go past a certain depth, that never becomes an issue, so only angle is needed.
Oh ok great! Thanks! I thought it could be an option to do pockets, instead of v-carving especially since I plan to do lines instead of dots, maybe I’ll export to png first to do that. Thanks for the tip!
