Where is pin D11
I’m looking for pin D11 on a 2.4 board any help would be great.
I am not saying I know what you need, but I think according to another program’s controller setup the D11 pin on an audrino board is for PWM and maybe the PWM pin is what you are looking for. See pictures:
this next is the upper right corner of my 2.4d controller board, see the PWM pin far upper right:
Hope it’s what you need, but I don’t know and am not saying it is. FWIW
That’s what I thought. I’m trying to control spindle speed through CM. Thanks
Would the PWM be useful if I only have the makita router or could it move the router positionally (not speed control) ? Wondering but don’t know what I’m wondering about…
Well right now the PWM will only bring my spindle up to 12000rpm instead of 24000. I had a potentiometer hooked up and the manual said to run it to 10 volt. Is that maybe my problem?
There are electronic boards which allow control of a trim router as if it’s a spindle — two options:
  • relays allow on/off by toggling the AC voltage on/off
  • VFDs/PIDs allow direct control including speed — the Makita is supposed to be too space-constrained for this
More at: https://shapeoko.com/wiki/index.php/Spindle_Control
