Happy New Year everyone,
Just finished modeling in Sketchup what will become my father’s bday present for this year.
My Nomad is out of reach and I haven’t had the chance to run any tests yet.
I’m pretty sure it will work though.
Feel free to give it a try!
Here’s a little bit of an update for this project.
I used 1/2” (12.7mm) hardwood carved down to 9mm for each side. The actual interiror ring diameter is 20mm and not 40mm as noted on the Sketchup model instructions. The total thickness once pieces are glued together is 18mm, a little bit less than 3/4”.
The piece feels fantastic to play with and spin around for hours to calm down the stress or praying, which it’s primary intended for.
